eflatt
Apr 07, 2024Follower
I would like to extend my Orbi 970 mesh outdoors does Netgear have a solution?
I have an Orbi 970 mesh in my home (one router, 3 sattelites), but I'd like to project the mes across my entire back yard. Do any Netgear products let me take an extender outside which is compatible...
Apr 10, 2024Guru - Experienced User
You can try one of these if you can find out and see if it works with the 970 series:
https://www.netgear.com/support/product/wax608y
https://www.netgear.com/support/product/wax610y
These are outdoor supporting. New tech in the Orbi 970 series, may or may not work.
