donawalt
Jun 24, 2025Hero - Experienced User
Installed 9.13.1.2 - initial results (positive)
I installed 9.13.1.2 on two 971s and a 970 Orbi router tonight. I am looking to test 6 basic issues I have seen on the 970 series; some of these may take days or even weeks to surface. But my test li...
donawalt
Jun 27, 2025Hero - Experienced User
It's early to declare victory, but in 3 days I have not had any memory creep situation on the 970s (which ends up in a crash/restart), or restarts independent of memory creep (which I have seen). I only had 1 flip to cellular 5G less than about 4 hours after upgrading to 9.13.1.2, but that was when I was testing IPv6, which is NOT ready for prime time (Netgear knows and is working on this) - so I disabled it.
I did a power-cycle after disabling IPv6, and no flips to 5G cellular in 2 days. Memory creep can take up to 2-3 weeks to show up, but if I go 2 weeks with no flips to cellular/loss of WiFi in the house I would say they nailed it. This FW is solid otherwise for me - streaming, speed, latency, packet loss all perfect. Here is a mid-afternoon workday zoom call latency/pkt loss tracking result:
- FURRYe38Jun 27, 2025Guru - Experienced User
Looking good. Fingers crossed.
- JWS9518Jun 27, 2025Luminary
I am seeing something weird with this new firmware. Tonight, I keep getting the red light on my router, app showing router offline, but my Roku continues to stream, my computer continues to stream, but on that same computer I cannot go to websites, even though I am streaming Spectrum on it. Certain devices offline. Red light of router on/off on/off and various intervals. I submitted a bug report to Ssu-Tuan via email. Error page on Edge says it can't find DNS.
Didn't have this behavior on previous firmware.
- donawaltJun 28, 2025Hero - Experienced User
JWS9518 you may have something else going on here. If it's just a simple case of the router not communicating with the modem/internet, the router is Magenta. Red pulsing light means the router thinks its WAN link or its own firmware is unhealthy – often a missed heartbeat to Netgear’s cloud or a brief loss of the ISP gateway. My theory is, existing TCP sessions stay up because they already know the server IPs and don’t need new DNS look-ups - so your Roku continues to stream. But fresh DNS queries from the PC are timing-out, so anything that needs a new IP address fails.
If you haven't taken these steps, I would try:
- Is there any way you can verify your ISP signal etc. is healthy - that they are not having any problems? I have Comcast for example, they have a status page which reports any issues, in addition to their app reporting that there are problems or maintenance in my neighborhood.
- What does your modem say is going on? I assume it shows no problems, log is clean, signals still good? If not the problem is there. Also, check cable connection between modem and router, they can come loose.
- Assuming no issues in #1 or #2, reboot through the Orbi router's web admin page at 192.168.1.1 - doing it there will reboot the satellites as well. Often a simple reboot will clear things up, especially after a firmware update.
- If it's on turn, off IPv6 setting on router admin page - Advanced tab, advanced section, IPv6. There are issues with it, NG is aware and is working on them. I actually have IPv6 turned off permanently.
- If the problem persists, as Netgear recommends, do a factory reset:
If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
This sends a Factory Reset command to any and all connected RBS as well.Here's a good procedure with all the detailed steps for doing a factory reset if you have to:
Re: Orbi Satellite Information and FAQ | NETGEAR Communities
Good luck and let us know how it goes!
