3sp3r4nz4
Aug 18, 2026Aspirant
IoT devices do not connect to the RBE970 (Satellite) when the RBE971 (Router) is in AP mode
Hello,
Same problem here.
After extensive testing, IoT devices do not connect to the RBE970 (Satellite) when the RBE971 (Router) is in AP mode; instead, all IoT devices connect to the RBE971,...
3sp3r4nz4
Thanks, I'll keep an eye on things too—please keep me posted. If it doesn't happen again on your end, I'll run some more tests...
Yes, cables are Cat8 STP.
Every change gets saved :)
I did see the info regarding AP mode configuration, but the host router can't monitor or manage the RBR's Wi-Fi connections—only the outgoing traffic.
Being able to manage Wi-Fi traffic on the RBR (and block certain devices) would have been nice, but it’s not the most important thing.
Aug 18, 2026Guru - Experienced User
FYI, reproduced the issue of IoT or Guest Network not seen when in AP mode. Just having my RBR online in AP mode, enabled IoT first, never appeared, then enabled GN and it never appeared.
Both showed enabled in the Orbi app and WEB UI.
Checked to see if phone would connect in the blind to the given SSID name with password and phone connected. Seems the IoT and GN is being hidden when in AP mode. Don't know why.
NG is aware of this and working on a fix. Hopefully be out in next FW update. For now, run in router mode.
- 3sp3r4nz4Aug 18, 2026Aspirant
Thanks for the follow-up and the tests confirming the issue.
So, all that's left is to wait.
Have a good day.
