3sp3r4nz4's avatar
3sp3r4nz4
IoT devices do not connect to the RBE970 (Satellite) when the RBE971 (Router) is in AP mode
Hello, Same problem here.   After extensive testing, IoT devices do not connect to the RBE970 (Satellite) when the RBE971 (Router) is in AP mode; instead, all IoT devices connect to the RBE971,...
  • FURRYe38's avatar
    Aug 18, 2026
    What FW version is on the RBR and RBS?
    What brand and model# host router is the RBR connected too?
    RBR using Dynamic or Static configuration for AP mode?
    How are the RBS connected to the RBR? Wireless or ethernet?
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
    What channel configurations are currently set on the router?
    How is the IoT network configured? Default SSID name or custom name?
    Using Both frequencies or a single frequency?
    How are you determining that your IoT devices are not connected to the RBS?
    How did you enable the IoT network? Using the RBR Web page or Orbi app?
