PaulGo
Jul 08, 2025Luminary
IPv6 Activation With Verizon FiOS
With the Orbi router (and previous Netgear routers) I found the only way to activate IPv6 is first use Auto Config. This will then default to 6to 4 Tunnel and give you a Router's IPv6 Address On L...
Jul 08, 2025Guru - Experienced User
Kewl, glad thats working. Thank you for the tip info. Hopefully helps others.
