PaulGo
Jul 08, 2025Luminary
IPv6 Activation With Verizon FiOS
With the Orbi router (and previous Netgear routers) I found the only way to activate IPv6 is first use Auto Config. This will then default to 6to 4 Tunnel and give you a Router's IPv6 Address On L...
GodLikePhase
Jul 09, 2025Apprentice
That RIPng setting does nothing for my Samsung s24+, I was losing ipv6 after a bit of time either way.
- FURRYe38Jul 09, 2025Guru - Experienced User
This maybe a work around for some and maybe not so much for others. May depend on ISP as awell. Over all this is a IPv6 issue that NG needs to resolve. If you need Ipv6 then use what works for you, older FW or configurations that may help. Otherwise users may need to disable IPv6 until NG gets something in FW that fixes all this.
- PaulGoJul 09, 2025Luminary
It's Comcast's fault as well as NG. Aside from the setup of IPv6 with Verizon I had had zero problems.
- GodLikePhaseJul 09, 2025Apprentice
Just curious though after you have been home for a while are you running random ipv6 tests on your phone?
Since you mentioned the issue I I have been checking daily or even more often. If I am in my house for a prolonged period of time I can lose IPv6 on my phone. Switching to cellular and back to WiFi resolves the problem for me. Perhaps it is a Samsung problem.
