PaulGo
Jul 08, 2025Luminary
IPv6 Activation With Verizon FiOS
With the Orbi router (and previous Netgear routers) I found the only way to activate IPv6 is first use Auto Config. This will then default to 6to 4 Tunnel and give you a Router's IPv6 Address On L...
GodLikePhase
Jul 09, 2025Apprentice
That RIPng setting does nothing for my Samsung s24+, I was losing ipv6 after a bit of time either way.
PaulGo
Jul 09, 2025Luminary
It's Comcast's fault as well as NG. Aside from the setup of IPv6 with Verizon I had had zero problems.
