PaulGo
Jul 08, 2025Luminary
IPv6 Activation With Verizon FiOS
With the Orbi router (and previous Netgear routers) I found the only way to activate IPv6 is first use Auto Config. This will then default to 6to 4 Tunnel and give you a Router's IPv6 Address On L...
donawalt
Jul 09, 2025Hero - Experienced User
With my devices, I’ve never found a reliable way to get it back. Sometimes even a hard reset fails to work, although most times that does. Sometimes switching automatic Wi-Fi 6E off, forcing it to 5 GHz, does it.
- PaulGoJul 10, 2025Luminary
I have, as a backup phone, the Motorola G 2025. I usually leave it off, but as a test I left it on. After 20 hours, it still retains IPv6. I this phone uses 802.11ac (Wi-Fi 5). So it appears the problem lies with Wi-Fi 6E and 7 implementation. I have had the Orbi since it was first available and with my Galaxy S21 I never lost ipV6 which I checked frequently since I was in the beta program. The S21 had Wi-Fi 6 (not 6E).
- GodLikePhaseJul 10, 2025Apprentice
I have an older moto phone I think 2021. It did stop ipv6 as well on builds after 10.5.10.10 till about build 10.5.18.4. I do not recall it happening on 10.5.19.5 but I was getting no ipv6 on my fire stick 4k max uses wifi 6e and my laptop using qualcomm wifi 7 card after a while which was new. The previous builds I had no issues at all with those devices.
