PaulGo
Jul 08, 2025Luminary
IPv6 Activation With Verizon FiOS
With the Orbi router (and previous Netgear routers) I found the only way to activate IPv6 is first use Auto Config. This will then default to 6to 4 Tunnel and give you a Router's IPv6 Address On L...
GodLikePhase
Jul 11, 2025Apprentice
Its cloudflares app to change dns easily for those that do not know how to do. Its on both stores from what I remember.
PaulGo
Jul 11, 2025Luminary
The current version does a lot more than that and now your IPv6 Internet provider appears to be Cloudflare.
