PaulGo
Jul 08, 2025Luminary
IPv6 Activation With Verizon FiOS
With the Orbi router (and previous Netgear routers) I found the only way to activate IPv6 is first use Auto Config. This will then default to 6to 4 Tunnel and give you a Router's IPv6 Address On L...
PaulGo
Jul 11, 2025Luminary
As a test I yesterday installed the WARP app on my wife's Galaxy S25, but I did not enable WARP so it just changed the DNS to 1.1.1.1. Her phone lost IPv6 while my phone which had WARP enabled did not.
Jul 11, 2025Guru - Experienced User
Seems like a good test comparison. Seems like the app helps where no app doesn't. Would be good to monitor this and let us know how it goes in 3 days.
Thanks for the details.
- PaulGoJul 11, 2025Luminary
I will do that. Since the app uses VPN to connect to Cloudflare for privacy that may be the key.
The WARP app has similarities to the T-Mobile cell spot device I have in my house which is connected to the internet. Through this device in my house for my T-Mobile phones and disconnect Wi-Fi I have reliable IPv6.
