PaulGo
Jul 08, 2025Luminary
IPv6 Activation With Verizon FiOS
With the Orbi router (and previous Netgear routers) I found the only way to activate IPv6 is first use Auto Config. This will then default to 6to 4 Tunnel and give you a Router's IPv6 Address On L...
Jul 11, 2025Guru - Experienced User
Seems like a good test comparison. Seems like the app helps where no app doesn't. Would be good to monitor this and let us know how it goes in 3 days.
Thanks for the details.
PaulGo
Jul 11, 2025Luminary
I will do that. Since the app uses VPN to connect to Cloudflare for privacy that may be the key.
