Jtcooper87's avatar
Feb 06, 2024
IPv6 setup help RBE972s
I just bought the RBE972s and I am having issues setting up IPv6. My service provider is Kinetic by Windtream. I know for a fact that they have IPv6 because it works with the rented router that they provided.
  • As info: I applied the "auto-detect" feature and after reboot came back as a 6to4 Tunnel, but doesn't seem to be working.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    Do you have the RBR connected behind another router?
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Try option #2 first...
    If you put the RBR in AP mode behind the ISP router, does IPv6 work then?
    NG is aware of some issues with IPv6.
    • Jtcooper87's avatar
      Jtcooper87
      Tutor
      1.So the RBE972s is running the latest firmware available: 9.10.4.1_1.1.17.
      2.I am not using the Orbi as a bridge currently. The Orbi is connected directly into the wall port using the supplied cable that came with the RBE972S.
      3.I was able to have Ipv6 at my house next door using a Netgear Nighthawk AX6 router (no modem/same ISP).
