rhg76's avatar
rhg76
Tutor
Nov 28, 2025
Is an upgrade worth it?
Hi there
Background
I have a RBR50 in AP mode, connected to 4 x satellites (RBS50) in my 5500 sq feet, 3 storey house.
We just about get coverage across the whole house but it doesn't stretch to our garage which is only 3 metres from the house.
We also have rubbish internet connection as we live in the sticks (no fibre). Getting download speeds of 44mbps download / 11mbps upload.
Question
Is it worth me upgrading to the newer models? Dual, Tri or Quad? The 970 series says it will cover 8200 sq feet with just a 3 pack.
Or could I try adding a 5th RBR50 satellite?
Any advice / lived experience welcome.
TIA
  • CrimpOn's avatar
    CrimpOn
    Depending on the composition of the house and garage walls (brick? metal?), it may be difficult to get a satellite in the garage to link with the existing systems in the house.  5G WiFi does not penetrate dense materials all that well.
    With a 44mbps internet feed, new WiFi technology will not make much of a difference in performance.
    p.s.  The marketing hype about speed and coverage is not something I would take seriously.
  • plemans's avatar
    With that distance betweem, run an ethernet wire and just wire in the garage. You can pickup those generation of used satellites for super cheap.
