kjx
Jun 17, 2025Apprentice
Is my satellite dead?
I have an Orbi 970 set - router + 4 satellites (5 devices). I’ve extended warranty and all that. Mine was one of those sets where the router was “overheating” and dropping. And putting a fan on t...
Jun 18, 2025Guru - Experienced User
Does it connect to the RBR with a ethernet wire connection in the back of the RBR?
Still happens with ALL RBS turned OFF accept for this one?
Might try a 30-30-30 reset on the RBS as well, then try to re-sync it.
If this fails, open up a support case.
What is the size of the home in sq ft?
