TOPS119
Nov 07, 2025Virtuoso
Is the new firmware working or not
I had issues downloading the new firmware 9.13.2.1 for the RBE 970 has a question sign on the file after download did they release a fix for this or is it the same old version being circulated with t...
- Nov 08, 2025
I did the update on the main Router which is the 791 and the other satellites auto updated. Thats different and new .
Nov 08, 2025Guru - Experienced User
You can always manually update. Its usually the process I recommend anyway as I'm not trusting of the auto-update and the app update method. I've seen to many issues/corruption posts from users using those methods.
