JJG1992
Oct 18, 2026Apprentice
It is a 10 Mbit/s half-duplex issue
It is a 10 Mbit/s half-duplex issue; I had the same problem with the tado internet bridge. The only way I could get it to work was to use a network switch instead of connecting directly to the RBE971...
schumaku
Oct 19, 2026Guru - Experienced User
JJG1992 wrote:It is a 10 Mbit/s half-duplex issue
Appears the Ethernet ports on "modern" (and fast) routers, network devices like Mesh satellites, does fail on the auto negotiation on 10Mbps half-duplex only devices like the tado Internet Bridge - and probably also on 10 Mbps full-duplex, 100 Mbps half- and full duplex devices.
Many popular ISP provided modern and fast routers (Salt Fiber, BT Hub, Sky Q Hub, Virgin Media, and EE Smart Hub routers for example) are affected, too:
The workaround suggested is deplyoing an unmanaged network switch: "if you’re still having issues, consider buying a 100/10 Mbit/s network switch"
By rule of thumb, all Netgear switches with Gigabit ports can be configured to 10 Mbps-half. For example GS108EPP:
This does not apply to the MultiGig and 10 GbE models - very similar to the Orbi 8 and Orbi 9 Series - where both auto and manual (where avaiulable) config is limited to 100M Full, 1G Full, 2.5G Full:
Very useful information, thank you JJG1992 !
And JulienR ... once more the in-line imgaes don't show up without a forced browser reload 8-(
