Flapman
Apr 07, 2026Tutor
Lag and intemittent connection issues on new Orbi 370
Hello, I recently upgraded my old Orbi system to a 370. Since then, I have regular network interruption issues on most of my main Wi-Fi-enabled devices. Sonos and Spectrum issues mostly. ...
Apr 08, 2026Guru - Experienced User
Flapman wrote:How do I accomplish #1. Would that require and add-on?
No add-ons needed.
Just log into the web management page using your browser, and click on "internet". Then select "Use These DNS Servers" in the "Domain Name Server (DNS) Address" section.
- CloudFlare IPs: 1.1.1.1 and 1.0.0.1
- Quad9 IPs: 9.9.9.9 and 149.112.112.112
- Google IPs: 8.8.8.8 and 8.8.4.4
Note you can mix and match (for instance, using 1.1.1.1 for primary, and 8.8.8.8 for secondary).
Best to reboot the router after doing this.
While this could be the issue, it seems unlikely, since your old Orbi was likely using your ISP DNS.
What model Orbi did you have before?
Flapman
Apr 08, 2026Tutor
Thanks. I'll do that when I get back home later.
My previous Orbi was a series 2 but I can remember the exact one.
