Flapman
Apr 07, 2026Tutor
Lag and intemittent connection issues on new Orbi 370
Hello, I recently upgraded my old Orbi system to a 370. Since then, I have regular network interruption issues on most of my main Wi-Fi-enabled devices. Sonos and Spectrum issues mostly. ...
Apr 08, 2026Guru - Experienced User
Flapman wrote:How do I accomplish #1. Would that require and add-on?
No add-ons needed.
Just log into the web management page using your browser, and click on "internet". Then select "Use These DNS Servers" in the "Domain Name Server (DNS) Address" section.
- CloudFlare IPs: 1.1.1.1 and 1.0.0.1
- Quad9 IPs: 9.9.9.9 and 149.112.112.112
- Google IPs: 8.8.8.8 and 8.8.4.4
Note you can mix and match (for instance, using 1.1.1.1 for primary, and 8.8.8.8 for secondary).
Best to reboot the router after doing this.
While this could be the issue, it seems unlikely, since your old Orbi was likely using your ISP DNS.
What model Orbi did you have before?
Flapman
Apr 13, 2026Tutor
I followed your recommendations.
I disabled Armor and set my DNS to the CloudFlare and Google IPs. However, now my internet is disconnecting more frequently. I was in the middle of a podcast this morning and got disconnected 3x.
Ideas?
- FURRYe38Apr 13, 2026Guru - Experienced User
Were you connected at the RBR or RBS when doing your podcast?
Try auto DNS again leave Armor disabled.
Set manual channesl 1 and 40 or 11 and 48.
I would power OFF both RBR and ISP modem for 1 minute then back ON.
Might try testing with a ethernet PC connected behind the ISP Modem to see if anything is noticed there.
Might try testing with the RBS turned OFF to see if only the RBR exhibit
- StephenBApr 13, 2026Guru - Experienced User
Agree that is an important question. Maybe try turning off the RBS units as a test, and see if the problem happens when connected to the RBR.
- FlapmanApr 13, 2026Tutor
It appears my laptops were connected to the RBS.
