superglide71
Oct 17, 2025Follower
larger coverage Area
Does Orbi allow to add more satellite to existing mesh, If so witch units will except this process. or can you join 2 mesh systems with same IP. What is the most distance out doors can most rece...
Oct 18, 2025Guru - Experienced User
superglide71 wrote:What is the most distance out doors can most receive, I have a 5 unit now but have very thick exterior walls
Is this the only problem you want to solve?
If so, is there a particular location where you need outdoor wifi (detached garage, shed, etc)? Or is it a broader area (perhaps needed for security cameras???).
It would be useful to understand the goals. It's possible that more orbi satellites might not be the right approach.
