radterrax's avatar
radterrax
Follower
Oct 05, 2026
Lenovo Chromebook Plus 14 no longer connects to my Orbi RBE971
My Lenovo Chromebook Plus 14 no longer connects to my Orbi RBE971 as well. It just stopped. My Chromebook Plus 14 laptop works with all other routers except my Orbi. This is ridiculous.
  • FURRYe38's avatar
    What Firmware version is currently loaded on the Orbi system?
    Was the chromebook recently updated? If so, you'll need to check with Google on this?
    Does the chromebook connect to the IoT or Guest Network if you configure something on 2.4Ghz with WPA or WPA2 security?
  • How long did the Chromebook connect to the Orbi before no longer connecting?
    Are any other WiFi devices in the house affected?
    p.s. a seven year old discussion about a different WiFi system may not be relevant.  It would have been better to start a new topic.
