Billy1956
Sep 07, 2026Tutor
Looking for answers
I have the 973 with 12.1.11.15. Orbi router connected to AT&T Gateway in passthrough and gateway radios turned off, Orbi in Router mode. Router on main floor. One satellite on main floor on the othe...
FrumpyGrandpa
Sep 07, 2026Luminary
The obvious answer is, "Yes. If the router Show Statistics reports a speed of 100mbps, that will affect the backhaul connection.
How about this:
- Connect the 970 satellite directly to the cable from the router (bypassing the switch)
- Connect the switch to one of the other 970 satellite ports.
- Connect the LG TV and the MRX 5 to the switch
Billy1956
Sep 08, 2026Tutor
The MRX5 and LG TV are connected to the switch. Connecting the Satellite directly to the Router would require running more wiring through the walls and floors. It's the switch that is connected to the router. Since the drop occurs when the satellite is in wifi backhaul also, is the drop occurring and only effecting the MRX5 and LG TV which the switch port is showing in the web interface. My question is since the satellite is also plugged into the switch is it effected also?
