timtim1192too
Nov 03, 2025Aspirant
Loosing WIFI (Internet) on single primary SSID
Brand new system of RBE971 w/ (3) RBE970 satellites all running V9.13.1.2 firmware, but I keep loosing INTERNET on the primary SSID, while the GUEST SSID is connected and working fine. Why? This ...
Nov 03, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Are RBS wireless or ethernet connected to the RBR?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
timtim1192too wrote:Brand new system of RBE971 w/ (3) RBE970 satellites all running V9.13.1.2 firmware, but I keep loosing INTERNET on the primary SSID, while the GUEST SSID is connected and working fine.
Why? This setup cost a fortune and should be rock solid...
timtim1192too
Nov 04, 2025Aspirant
Answers to your questions:
- Size of house is irrelevant when the router is loosing connectivity to the FIOS ONT (brand new - 2.5 gig speed when working)
- Distance btw RBR & RBS also irrelevant as that connectivity is rock solid
- If I turn off RBS, yes RBR still looses connection to the FIOS ONY
- Channel config is irrelevant as issue is RBR loosing connection over a wired (cat7 Ubiquiti cable) to ONT
- FURRYe38Nov 04, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Is IPv6 enabled on the RBR?
- timtim1192tooNov 04, 2025Aspirant
You might be onto something. Just checked the Ubiquiti web site and their cables only support GBE. Just ordered a CAT8...
Just curious how it would impact only one SSID and not all 3 SSIDs.
Make sure the cable is STP rated.
Also I would update the Orbi system as new FW has been put forth to help test this:
Orbi Firmware Releases | NETGEAR Communities
