timtim1192too
Nov 03, 2025Aspirant
Loosing WIFI (Internet) on single primary SSID
Brand new system of RBE971 w/ (3) RBE970 satellites all running V9.13.1.2 firmware, but I keep loosing INTERNET on the primary SSID, while the GUEST SSID is connected and working fine. Why? This ...
CrimpOn
Nov 03, 2025Guru - Experienced User
timtim1192too wrote:All the devices on that primary SSID loose connectivity.
Perhaps not helpful to the discussion, but..... When devices are connected to the Primary WiFi SSID:
- Do they appear in the Attached Devices display with IP addresses?
- Is it possible to communicate with them on the LAN? (perhaps 'ping' their IP address?)
- How is the Access Control feature set on this router?
(page 54 of the User Manual)
timtim1192too
Nov 04, 2025Aspirant
- Yes, attached devices still display with IP address, DHCP on router is working fine. Issue is connectivity btw router and FIOS ONT
- Yes, inside LAN is fully functional
- Access control feature is irrelevant for this issue
