timtim1192too
Nov 03, 2025Aspirant
Loosing WIFI (Internet) on single primary SSID
Brand new system of RBE971 w/ (3) RBE970 satellites all running V9.13.1.2 firmware, but I keep loosing INTERNET on the primary SSID, while the GUEST SSID is connected and working fine. Why? This ...
timtim1192too
Nov 06, 2025Aspirant
November 6th update:
- Yes - Bitdefender Armor is enabled on router - remember issue is just on a single SSID at a time while the other 2 have internet access
- Replaced ethernet cable btw router and ONT w/ a STP Cat 8 cable ~15 feet away from each other
- Upgraded to the latest FW released on Oct 31st on all satellites and router
Still occurring. At 1st it was just the primary SSID, now it seems to be random. This morning the IoT SSID lost internet connectivity
Nov 06, 2025Guru - Experienced User
I recommend you open a support ticket with NG support and reference this forum thread.
- timtim1192tooNov 06, 2025Aspirant
ONT is Calix 812NG-V
- FURRYe38Nov 06, 2025Guru - Experienced User
Ok, I'll pass this on to NG as well.
Is this the unit you have?
https://astound-prod.mindtouch.us/all-equipment/internet-equipment/fiber-to-the-home-equipment/calix-gigahub-812g-ont-all-in-one
