Pacspud
Apr 27, 2026Aspirant
Manual update to 9.13.2.1 from V9.12.3.3_1.2.20
I had two Orbi 970 systems, both running 9.12.3.3_1.2.20. I tried to manually update one to 9.13.2.1 downloaded from the Netgear support site. The satellites worked fine. The router bricked. I am...
krgoodwin
Apr 27, 2026Apprentice
Digging further into my system's documentation, I found a detailed set of firmware update instructions that go beyond the level of detail in the User Manual. It is done first for the satellites and then the router. Hopefully I can send it to you via the attachment mechanism of this blog.
