cargal
Jan 28, 2026Aspirant
Migrate from RBR 50 to RBE 773
Has anybody undertaken the above migration in order to retain all the setting from the RBR50 to the new RBE 773 so as not to have to setup every device again? If so, would greatly appreciate the ...
Jan 29, 2026Guru - Experienced User
Usually you don't have to setup every device again if you re-use your same SSID and password. The devices should just auto-connect. I've been doing it for a while and I haven't had a device not connect yet.
cargal
Jan 29, 2026Aspirant
Perfect - i will be retaining the SSID and P/W... so hopefully it works - thank you
