DocRJNC's avatar
DocRJNC
Tutor
Dec 08, 2025
Migration from RBR 850 to Orbi 970
Good morning.
Looking for some insight.   I am in the process of upgrading my orbi 850 to 970.  I have a lot of cameras and IoT devices, and I have seen an increase in drops during streaming/Zoom calls over the past 5 months.
I want to keep the same SSID name so my devices auto-connect when the new router comes online.
Has anybody had any experience with this and could provide some easy steps?
I would be so very grateful.
Robert Jones
  • Yes,
    Have the 970 series and any RBS in same room and not connected to the ISP modem/ONT. You can set up the system off line from the ISP service.
    You can set up the 970 series and use same SSID name and password.
    Once you get the new system setup. Turn OFF the new RBS. Place them at same locations at outgoing RBS but don't turn them ON.
    Place the new RBR near the outgoing RBR. Don't turn yet.
    Turn OFF outgoing RBS.
    Reboot the ISP modem or ONT. As the modem/ONT is rebooting, disconnect the out going RBR from the modem/ONT and connect the NEW RBR to the modem/ONT and power it ON. Keep the outgoing RBR ON for now. Disconnect any ethernet devices from the outgoing RBR and connect them to the new RBR.
    Once the ISP modem/ONT and new RBR have come to ready, can run a quick check with a wired PC to make sure you have internet access here. Front LED on the NEW RBR should be OFF.
    If all is good here, turn OFF the outgoing RBR.
    Your wifi devices should auto migrate and connect to the new RBR.
    Turn ON the new RBS at there remote locations. I recommend powering on one RBS at a time giving 30 seconds to 1 minute before turning ON the next one.
    I do this same process when I put a different system online to test. Works well.
  • FURRYe38's avatar
    Yes,
  • Wow,
    Thanks so much for the response.  It's great to know this shouldn't be a big issue.  One additional question; how do you setup the new system off line from the ISP?  Connect from my laptop to the new orbi via network cable?
    Robert
  • Thank you so much for sharing your knowledge/experience.   I am going to put this into practice after my 1 pm conference call.
    Robert
  • Good evening.
    Things got a little hairy for a minute (Orbi couldn't be found; old router refused to go away, etc).  But we persevered, and things are running rather smoothly now.  Did not have as much drama as I anticipated.
    Once I get my Net Armor protection in place.  We are back running.  The new router does appear to be quicker and most responsve to my IoT devices.
    Thanks for your help.
    Robert
