birdiesatx
May 22, 2025Follower
My 770 router and satellite
I have the same exact scenario and issue with my 770 router and satellite! The only difference is that my ISP swapped out my old fashioned modem for a Gigaspire modem and I can't help but think it's also part of the problem
1 Reply
Does the front LED on the RBR or RBS turn PINK or blink WHITE when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.If the system worked before the ISP changed out the modem, seems like maybe a ISP issue with the new modem.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-orbi-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457046Disable all logging on the RBR...
