TOPS119
Jul 22, 2026Virtuoso
My RBR has ridiculous ping after 12. update
Has this happen to anybody else where the ping is so high on the rbr but the satellites have the correct ping ? my speed test is terrible on the main router but on the satellites its ok, this happens...
- Jul 28, 2026
So after multiple days with the orbi team my issue of the router giving slow wrong speeds has been fix with this new update I am going to continue watching to see if anything else was broken in the process but I can confirm now that this new firmware fix that particular wifi issue.
Jul 22, 2026Guru - Experienced User
How are you testing pings? Ethernet or wireless?
What pings values are you seeing?
How many devices are connected to the system in total?
TOPS119
So I have 1gb up and down and this is what I get I have less than 40connected use to work fine before the update. I did a reset of the router same thing.
- FURRYe38Jul 22, 2026Guru - Experienced User
Is this tested on a ethernet PC or wireless?
What brand and model# ISP modem or ONT is the RBR connected too?
Is IPv6 enabled?
Any features enabled like Armor or SPC?
What is CAT# LAN cable between the RBR and ISP modem/ONT?
Same thing seen with ethernet PC directly connected to the ISP modem/ONT?
- TOPS119Jul 22, 2026Virtuoso
Some of these questions bro not necessary as the system been working for years this start happening after the update. But let me answer
im using the required cat 6
armor is connected test was done turn it off and on still never work
ipv6 is off
Bran the modem is connected to is a sercom
I have re ran the firmware same thing. I have factory reset same thing
I have not tested on ethernet because as I said the satellites works fine and they are hard wired.(right speeds and reeding) its just the RBR is the issue.
Is the cable UTP or STP? STP makes a difference.
There a model # of the sercom modem?
Which ISP are you connected with?
What region are you located?
Sorry but questions are necessary for us to help troubleshoot the issue and narrow down where the issue or cause is. The more details and information we can can help NG review this.
Your the only one seeming to be having this issue.
I have v12 loaded on mine and have never seen this. Though mines connected to a cable modem. CM3000.
Furry it's the wireless is the issue the Wi-Fi signal it's sending out isn't correct
Brand and model# wifi device your connecting to the RBR?
What channels are you using on the RBR?
