TOPS119
Jul 22, 2026Virtuoso
My RBR has ridiculous ping after 12. update
Has this happen to anybody else where the ping is so high on the rbr but the satellites have the correct ping ? my speed test is terrible on the main router but on the satellites its ok, this happens...
- Jul 28, 2026
So after multiple days with the orbi team my issue of the router giving slow wrong speeds has been fix with this new update I am going to continue watching to see if anything else was broken in the process but I can confirm now that this new firmware fix that particular wifi issue.
TOPS119
Here is a speed test directly from the orbi app
Jul 22, 2026Guru - Experienced User
Seems to be getting to spec speeds with Orbi app thru the RBR...
- HappyCatJul 22, 2026Virtuoso
Thanks for taking the time to record and post the Speed Test results from the router. This does seem to indicate that the issue is related to the WiFi connection of this specific device.
Some cell phones report the "Link Rate" of their WiFi connection. The Orbi 'app' Device Manager also reports it.
- TOPS119Jul 22, 2026Virtuoso
Yes im having a wifi issue.. Just find it hard to have to wait on an update for the issue to get fix knowing these updates dont come regularly...
- FURRYe38Jul 22, 2026Guru - Experienced User
There a model # of the sercom modem?
Which ISP are you connected with?
What region are you located?
Brand and model# wifi device your connecting to the RBR?
What channels are you using on the RBR?
