TOPS119
Jul 22, 2026Virtuoso
My RBR has ridiculous ping after 12. update
Has this happen to anybody else where the ping is so high on the rbr but the satellites have the correct ping ? my speed test is terrible on the main router but on the satellites its ok, this happens...
- Jul 28, 2026
So after multiple days with the orbi team my issue of the router giving slow wrong speeds has been fix with this new update I am going to continue watching to see if anything else was broken in the process but I can confirm now that this new firmware fix that particular wifi issue.
TOPS119
Jul 24, 2026Virtuoso
No disrespect but I've wrote all of them in previous post above. But let's say it again.
1 I have reset the RBR
2 I have loaded over the firmware
3 I have turned off all additions like armour
Jul 24, 2026Guru - Experienced User
TOPS119 wrote:1 I have reset the RBR
Thx. Have you tried a test with the RBS all turned off - just to ensure that your device was connected to the RBR?
- TOPS119Jul 25, 2026Virtuoso
I will do that test now but RBR is downstairs and the appliances downstairs is connected to it now with no issue.. the issue is that the wifi not sending out the correct signal. But I will try that as you suggested.
