TOPS119
Jul 22, 2026Virtuoso
My RBR has ridiculous ping after 12. update
Has this happen to anybody else where the ping is so high on the rbr but the satellites have the correct ping ? my speed test is terrible on the main router but on the satellites its ok, this happens...
- Jul 28, 2026
So after multiple days with the orbi team my issue of the router giving slow wrong speeds has been fix with this new update I am going to continue watching to see if anything else was broken in the process but I can confirm now that this new firmware fix that particular wifi issue.
TOPS119
Jul 25, 2026Virtuoso
Test was done same issue everything now connects to the RBR but the wifi signal is strong but gives off very poor reading
Jul 25, 2026Guru - Experienced User
There a model # of the sercom modem?
Which ISP are you connected with?
What region are you located?
Brand and model# wifi device your connecting to the RBR?
What channels are you using on the RBR?
