varloca3
Feb 23, 2026Follower
Netgear Orbi 370
Couple questions that hopefully are easy to answer (I'll give context first), I'm looking to revamp my home network system, i currently use my ISP router which while its good doesn't cover the whole ...
Feb 23, 2026Guru - Experienced User
How big is the home. Size of home, building materials will factor in how many RBS you should consider. Smaller sized homes, generally just need the main router unit and one maybe two RBS. Larger sized homes, two or more RBS maybe needed. I have a 5K multi level home and get away with two RBS. Wireless or ethernet connected.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite🛰
No, need to use the DC power brick that comes with them.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communities
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Brand and model# of LAN switch you'll be using with the system?
