kingjh2
Nov 16, 2025Aspirant
Netgear Orbi 970 wired backhaul issues
I have a Netgear Orbi 970 series with one router and two satellites. I had my satellites connected using 10g port via CAT 6A to XS508M switch and then to the router to the 10g lan port. The router wo...
Nov 16, 2025Guru - Experienced User
kingjh2 wrote:Any recommendations?
I suggest starting by using the wired backhaul only between the router and the most distant satellite (leaving the other using wireless backhaul). Then maybe repeat that test with only the closer satelite using the wired backhaul.
