kingjh2
Nov 16, 2025Aspirant
Netgear Orbi 970 wired backhaul issues
I have a Netgear Orbi 970 series with one router and two satellites. I had my satellites connected using 10g port via CAT 6A to XS508M switch and then to the router to the 10g lan port. The router wo...
Nov 16, 2025Guru - Experienced User
Was the RBS first wirelessly connected to the RBR, then ethernet connected?
What FW version is loaded on the RBR and RBS?
Which ports on the switch are you using?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Brand and model# of ISP modem the RBR is connected too?
Just had my 970 series online before moving to a different system. Also have same non managed switch mode and has not been powered cycled in a long time. Zero issues. Both RBS ethernet connected to this switch.
kingjh2 wrote:I have a Netgear Orbi 970 series with one router and two satellites. I had my satellites connected using 10g port via CAT 6A to XS508M switch and then to the router to the 10g lan port. The router would reboot randomly to where I had the original router RMA'd, but the current router has the same issues. Netgear support requested that I disconnect the wired backhaul and just use wireless backhaul to test the theory of a broadcast storm on the switch causing the issue. It's been 2 days so far with no issues, but I have seen the router up for 8 days in it's previous configuration so will continue to monitor. If the issue does not reappear using wireless backhaul I was going to clear the mac address table in the switch by disconnecting power for a bit and then connect router, sat 1, and sat 2 one at a time. All gear is on an UPS.
Anyone else have issues using unmanaged switch for wired backhaul? Any recommendations?
kingjh2
I setup while wired as I repeated the setup process when I started having issues.
Support had me upgrade to V9.13.2.1_1.3.35 which was recently released.
Ports 1 and 2 for satellites and port 8 for router.
Home is 6000 sq ft. Satellites are more than 30 ft from router.
AT&T BGW320 gateway
