kingjh2
Nov 16, 2025Aspirant
Netgear Orbi 970 wired backhaul issues
I have a Netgear Orbi 970 series with one router and two satellites. I had my satellites connected using 10g port via CAT 6A to XS508M switch and then to the router to the 10g lan port. The router wo...
kingjh2
During setup I had the satellites wired.
Support had me upgrade firmware to V9.13.2.1_1.3.35 which was recently released.
Using ports 1 and 2 for satellites and 8 for router.
6000 sq ft house. Satellites are more than 30ft away.
AT&T BGW320 gateway
Nov 17, 2025Guru - Experienced User
Orbi tends to prefer having the RBS wirelessly connect first, then once they are fully synced there, then ethernet connect them.
What happens if you use port 1 for the RBR on the XS switch, then ports 2 and 3 for RBS?
Be sure your RBR is using the gateways DMZ or IP pass thru feature to avoid the double NAT condition.
- kingjh2Nov 17, 2025Aspirant
Not changing anything right now at least for another 5 days just to ensure another reboot does not occur. I will then plug in the router and one satellite to see how it operates and then the other satellite. I'm hoping by clearing the mac address table in the switch that it will operate correctly.
Gateway is in IP-Passthrough mode.
- FURRYe38Nov 17, 2025Guru - Experienced User
Let us know how it goes.
