kingjh2
Nov 16, 2025Aspirant
Netgear Orbi 970 wired backhaul issues
I have a Netgear Orbi 970 series with one router and two satellites. I had my satellites connected using 10g port via CAT 6A to XS508M switch and then to the router to the 10g lan port. The router wo...
CrimpOn
Nov 19, 2025Guru - Experienced User
kingjh2 wrote:just use wireless backhaul to test the theory of a broadcast storm on the switch causing the issue.
When attempting to diagnose network problems, erratic behavior that happens at random intervals is very difficult. What we all would prefer is a condition that can be replicated at will. i.e. "I do this and then that happens... every time!" in this case:
kingjh2 wrote:I have seen the router up for 8 days in its previous configuration so will continue to monitor.
It might be useful to keep a log of when these outages occur and what equipment is connected to the network at the time. It might be helpful to set the debug option to Start Debug Log Capture when boot up. I have never seen documentation regarding how to interpret the debug log, but there might be information about what caused the system to restart.
kingjh2
Nov 19, 2025Aspirant
I have over 120 devices on the network which has been functioning fine since unplugging the satellites. The only devices that were using the switch in question were the router and the two satellites on the 10g ports. I just added the switch back with the router and one satellite so will see how this goes.
