Blairgowrie
Aug 26, 2025Aspirant
New 770 series coverage
Disappointed with the coverage of my new 770 series system . I bought it to replace an AC3000 series that had gone to no support. The new Router and satellites are in exactly the same position as t...
Aug 27, 2025Guru - Experienced User
How are you determining the new system has less coverage?
What kinds of devices do you have connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
Be sure to post in the right forum for technical support, help and information. The Feedback section is not for this.
