texasTrio's avatar
texasTrio
New Orbi 370 RBE371 can't connect to Google Home
12/2025 Installed a new Orbi 370 today.  Got most devices connected.  Tried a bunch of times to get the Google Home connected.  The chromecast works. I enter the SSID and password into the Google Ho...
  • texasTrio's avatar
    texasTrio
    Dec 10, 2025
    I do keep the same ssid. I fixed the problem.  I moved to another room thinking there may be signal interference (unlikely).  I removed all home definitions from Home in the app by clicking my google account icon. Presto. Next connect attempt worked.
    The orbi 370 is fast. However not appreciating that I can't hide the ssid.  I can't change the channel also. All of the routers in my are are stacked on the same channel....
