Coachcasa
Aug 16, 2025Aspirant
New Orbi 370 Router
Hi. i just hooked up my new Orbi 370 dual band Wifi 7 Mesh router with 1 satellite. Before this I was using an Orbi RB50 Wifi 5 Mesh router with 1 satellite. After setting up the new router, I'm t...
Aug 16, 2025Guru - Experienced User
What are the ethernet connected speeds seen?
What brand and model wireless device are you speed testing with?
Be sure it's connected to the RBR for best results. Can turn OFF the RBS temporarily while testing.
Be sure to speed test using Orbi app, then Ooklas installable speed test app.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Coachcasa
When I connected the routers, I updated to the latest firmware today. The ethernet speed at last test is 970mb down and 940 up. This is from the Orbi app.Using the Ookla Speedtest app I got 482 down and 534 up. With the Speedtest browser site I got 410 down and 634 up. These numbers aren't very different from what I was used to seeing with my old router. It was usually between 375-500 down. The ISP is i3 Broadband and I'm using their DZS router bringing the fiber optic cable inside the house. Thanks for replying.
