Coachcasa
Aug 16, 2025Aspirant
New Orbi 370 Router
Hi. i just hooked up my new Orbi 370 dual band Wifi 7 Mesh router with 1 satellite. Before this I was using an Orbi RB50 Wifi 5 Mesh router with 1 satellite. After setting up the new router, I'm t...
Aug 16, 2025Guru - Experienced User
What are the ethernet connected speeds seen?
What brand and model wireless device are you speed testing with?
Be sure it's connected to the RBR for best results. Can turn OFF the RBS temporarily while testing.
Be sure to speed test using Orbi app, then Ooklas installable speed test app.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Coachcasa
Now testing again through the speedtest app, I got 511 down and 753 up. It seems to be getting faster over the last few hours. I'm wondering if there is an adjustment period?
