Coachcasa
Aug 16, 2025Aspirant
New Orbi 370 Router
Hi. i just hooked up my new Orbi 370 dual band Wifi 7 Mesh router with 1 satellite. Before this I was using an Orbi RB50 Wifi 5 Mesh router with 1 satellite. After setting up the new router, I'm t...
CrimpOn
Aug 16, 2025Guru - Experienced User
Coachcasa wrote:wondering if there is an adjustment period?
No. My experience is that ISP speed can change over time as the aggregate load from their subscribers changes.
The device being used to measure speed over WiFi is a critical piece of information. While WiFi7 offers higher potential speed over WiFi6 and WiFi5, only a device capable of WiFi7 can take advantage of it. Also, speed over WiFi is affected by distance from the WiFi access point.
