Gurjeee
Jul 07, 2026Guide
No internet on Guest Network Orbi 970
Hi, I recently purchased 2 pack Orbi 970, To be used as Network extender. basically after setting up the guest network, I tried to log in, but once logged in, i get a notification guest net...
- Jul 09, 2026
Hi, I thought I'd come on here to give you an update.
Everything is now working as it should, including the Guest Network.
The only problem I was having, was logging back in to RBR after full reset, I kept getting the password reset loop, but once I sorted the issue, I setup the WIFI networks again, put the RBR in AP mode, restarted my ISP router 1st, once fully booted up, I plugged the Ethernet cable into RBR 10G internet port, tested the guest network, and it is now working fine.
Thank you both for your help. it has been a steep learning curve, going from a TP link router to the Orbi 970. Everything is sorted, including the satellite.
Thank you again
HappyCat
Jul 07, 2026Virtuoso
Is this system in 'Router mode' or 'Access Point mode'?
- GurjeeeJul 07, 2026Guide
Currently in router mode, with DHCP disabled, as my ISP router assigning IP address.
- HappyCatJul 07, 2026Virtuoso
I fear that cannot work. The modern Orbi series expects devices on the Guest WiFi network to have IP addresses in a different IP subnet than the primary and IoT networks. The DHCP request made by devices connected to the Guest WiFi will not be transmitted through the WAN interface.
A quick check would be to look at the Attached devices display and see what IP address is assigned to devices connected to the Guest WiFi network.
- GurjeeeJul 08, 2026Guide
When I had DHCP enabled on the RBR I had IP conflicts, as my ISP router and the RBR, where both assigning IP addresses, and some of my smart devices i.e smart blind hub would not connect to the internet, once I disabled DHCP on the RBR then everything worked fine. Apart from the guest network. I have nothing plugged into the WAN 10G ports , on the RBR, the only ports I am using on the RBR, are the 2.5. So are you saying I need to enable AP on the RBR. I am only going by what settings I had on my TP link Archer c7 1750 V2.
- FURRYe38Jul 08, 2026Guru - Experienced User
You'll need to set DHCP to enabled and then if your ISP modem is using same IP address as RBR does, you can change the IP address of the RBR to something else. Try 192.168.0.1. What I use for router mode for any router I put online. Or configure the RBR for AP mode, let the ISP router handle router operations and then you can continue to use Guest Network. Or you could change the ISP routers IP address to something else as well, and use default IP addressing on the RBR.
