Gurjeee
Jul 07, 2026Guide
No internet on Guest Network Orbi 970
Hi, I recently purchased 2 pack Orbi 970, To be used as Network extender. basically after setting up the guest network, I tried to log in, but once logged in, i get a notification guest net...
- Jul 09, 2026
Hi, I thought I'd come on here to give you an update.
Everything is now working as it should, including the Guest Network.
The only problem I was having, was logging back in to RBR after full reset, I kept getting the password reset loop, but once I sorted the issue, I setup the WIFI networks again, put the RBR in AP mode, restarted my ISP router 1st, once fully booted up, I plugged the Ethernet cable into RBR 10G internet port, tested the guest network, and it is now working fine.
Thank you both for your help. it has been a steep learning curve, going from a TP link router to the Orbi 970. Everything is sorted, including the satellite.
Thank you again
Jul 07, 2026Guru - Experienced User
FW for the EU region is on the horizon. If all goes well.
Brand and model# of the ISP modem or ONT that the RBR is connected too?
Are you getting any Guest Network connection from the RBR with out the RBS being connected?
How is the RBS connected to the RBR? Wireless or Ethernet?
What brand and model# devices are you connecting to the Guest Network?
What channels are you using on the RBR for 2.4 and 5Ghz?
Guest Network is working for me, however I'm in the NA region and my system is in AP Mode.
- GurjeeeJul 07, 2026Guide
My ISP is Youfibre 2Gbps symmetrical, and my ISP router is Sagemcon WIFI 7 router.
The 2.5Gbps port on ISP router is connected to a 2.5Gbps 5 port Netgear unmanaged switch, The switch provides the backhaul to the RBR and connected to the 2.5Gbps port on the RBR.
The RBS is wireless and is placed upstairs.
I am just currently trying to connect my Android Sony Phone. And have set the RBS and RBR to use both band 2.4Ghz and 5Ghz.
I haven't turned AP mode on, but DHCP is disabled on RBR. I am assuming what ever settings I set on the RBR, the RBS will mirror the RBR.
