Gurjeee's avatar
Gurjeee
Guide
Jul 07, 2026
No internet on Guest Network Orbi 970
Hi,    I recently purchased 2 pack Orbi 970, To be used as Network extender.    basically after setting up the guest network, I tried to log in, but once logged in, i get a notification guest net...
  • Gurjeee's avatar
    Gurjeee
    Jul 09, 2026
    FURRYe38​ StephenB​
    Hi, I thought I'd come on here to give you an update.
    Everything is now working as it should, including the Guest Network.
    The only problem I  was having, was  logging back in to RBR after full reset, I kept getting the password reset loop, but once I sorted the issue, I setup the WIFI networks again, put the RBR in AP mode, restarted my ISP router 1st, once fully booted up, I plugged the Ethernet cable into RBR 10G internet port, tested the guest network, and it is now working fine.
    Thank you both for your help. it has been a steep learning curve, going from a TP link router to the Orbi 970. Everything is sorted, including the satellite.
    Thank you again
