dglsmcd_USMC
Jun 13, 2026Luminary
Notice-New-Firmware Orbi 971/970 V12.1.10.12_5.3.16 NA Only
New firmware for Orbi 971/970 V12.1.10.12_5.3.16 currently available only through the Orbi app. Router and satellites upgraded to the new firmware via the Orbi app with no issues. No release notes av...
Jun 13, 2026Guru - Experienced User
FW is being pushed to a few select customers. So not everyone will see this and is Not full public release yet. I think there just toe tip testing the waters. I've ask for release notes.
Not sure if this will be final build or just something to check with some users.
Please post here if you notice issues with FW update, update process and any issues seen after your system has been updated.
This is being checked with the EU region as well.
- Bosko22Jun 14, 2026Tutor
I wonder why this is not considered a beta release. Limited release, presumably just testing the waters before a formal full release..seems to match the definition of beta.
This release process may be a first for Netgear.
Also this is the first time my Orbi app actually indicated a firmware upgrade available after having used it for years!- FURRYe38Jun 14, 2026Guru - Experienced User
Yes since this is a Major release and update, NG seems to want to test the waters and be sure that normal uppdate processes are working. Since v12 is on the plan going forward, there is now downgrading back to official v9 FW. Lots of new stuff in v12 and should be good.
Also you'll see protection engine feature as well in v12 FW. This will help resolve testing issues seen at Gibson Research testing site for ShieldsUp!
