dglsmcd_USMC
Jun 13, 2026Luminary
Notice-New-Firmware Orbi 971/970 V12.1.10.12_5.3.16 NA Only
New firmware for Orbi 971/970 V12.1.10.12_5.3.16 currently available only through the Orbi app. Router and satellites upgraded to the new firmware via the Orbi app with no issues. No release notes av...
Jun 24, 2026Guru - Experienced User
Did you manually update your system or let the system auto update?
Is IPv6 enabled on your RBR? just curious.
Ely wrote:Updated my RBE971 router and my RBE970 satellite today, no issues so far. Hopefully, this will fix an issue I was having with my Pixel phone, where it would randomly just disconnect from the network. Fingers crossed. It's been quite a while since my Orbi received any update. Monitoring carefully.
TOPS119
Jun 24, 2026Virtuoso
It seems to have fix the pixel disconnecting issue so far. I have one issue when I do a speed test with the pixel it gives me way below the speed it should I'm trying to figure this one out. Using speed test.net
- ElyJun 24, 2026Luminary
Glad to hear, yeah, I haven't noticed any disconnection with my Pixel 10 Pro XL either
