Magicmomo
Oct 10, 2025Aspirant
Orbi 370 no internet
Orbi 370 cannot access the Internet in Germany with FRITZ!Box 7530 AX Everything else in the setup with the app worked without any problems. Is this a known issue? Does anyone know of a solution?...
Magicmomo
Oct 17, 2025Aspirant
Solved, thank you
Oct 17, 2025Guru - Experienced User
Please let us know what solved it for you. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
