Snoocher
Oct 17, 2025Tutor
ORBI 370 Poor Download Speeds
Hi - Just replaced my 8 year old ORBI RBR50WiFi 5 system. My WiFi speeds are no better most of the time than with that older model. Have 2 satellites, each on a different floor from my router an...
Oct 17, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
Armor, Smart Parental Controls or Circle, IPv6, Traffic Meter.
Some near by networks can cause some interfernece issues. Especially in city environments.
Snoocher
Oct 17, 2025Tutor
Thanks. It’s ATT Fiber, the modem is BGW320. Wired speeds are near 1GB. The wireless speeds are the issue.
FW is the most recent.
LAN cable is CAT7.
Router is on a different floor than the satellites. Definitely 30+ feet away. We have a very open floor plan home.
Channels are 11 and 161 as advised by Netgear.
Turned off rotating MAC addresses on my iPhone 16 Pro. No difference in speeds.
- FURRYe38Oct 17, 2025Guru - Experienced User
And if you turn OFF the RBS and connect the phone near the RBR say 10 feet away and use Ooklas installable speed test app, speeds are not good?
Please try channels 1 and 40 on the RBR.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: Static IP Address Configuration for AP Mode | NETGEAR Communitieshttps://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- SnoocherOct 17, 2025Tutor
Speeds can be close to 700/500 in that scenario, but not always. Are you thinking the satellites are the issue? That’s where my head is.
- FURRYe38Oct 18, 2025Guru - Experienced User
What FW version # is loaded on the sytem currently?
Please enable 240MHz in the advanced settings on the RBRs web page.
