GatorMitch
Dec 22, 2025Aspirant
Orbi 370 Satellite Speed is bad
I thought I was upgrading from my RBR50 and 1 satellite that died by getting the Orbi 370 and 1 satellite. Wow was I wrong. I have 500 speed fiber. Wireless that sees the router gets great speed, ...
Dec 22, 2025Guru - Experienced User
The RBE370 is the most base model system without a dedicated backhaul. The RBK50 was the flagship at its time. Thats why. To see faster peak speeds, you'd need to upgrade more.
I'd take a look at Dong Ngo's review of wifi 7 mesh systems. Take a look at the performances and expectations as well as price. Then choose.
https://dongknows.com/best-five-wi-fi-7-mesh-systems/
He does review the lower end systems too so its worth checking those out if you're on more of a budget.
- GatorMitchDec 22, 2025Aspirant
Thanks for the link. When I read the features for the 370 it says it has enhanced backhaul (MLO). Are you saying it doesn't have a dedicated backhaul to connect the satellite to the router? I can't figure out if any other similar priced set up has a dedicated backhaul.
- StephenBDec 23, 2025Guru - Experienced User
It does not.
FWIW, high-end WiFi 7 routers have three client bands - 2.4 ghz, 5 ghz, and 6 ghz. They are trending away from a dedicated backhaul network, since the extra 6 ghz band adds enough bandwidth to allow running the backhaul over the same radios.
Is the backhaul to your satellite using 5 Ghz? Also, do you know what band the client is connecting with?
